- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
It is possible. Solutions move.The cross-contamination you folks are talking about-Can it end up affecting the contents inside the cartridges, or does it only result occur at the print head and stay there/on the paper?
I'm asking just because, as I reported earlier, my yellow tank contents are very dark, and almost look like black.
No so fast... if you examined a printhead internally, or check the order of the nozzle bank on the UNDERSIDE. They do not always line up in the same fashion as the way carts are installed on top! in other words, the route is not direct for a reason......there is one pump. You need to engineer the flow resistance to be equal amongst all the carts. If this is not done, a head clean will NOT pull the same amount of ink across all colors.Here is the cartridge layout on the iP6600, and with the black at the other end of the cartridge line, the only other possibility is silicone gasket failure, causing cross contamination inside the head itself...
View attachment 5485 If this is the case then it's game over...![]()
