IP4300 - PGBK not printing: Clogged head or what?
Łukasz
Poland
MG6250 (MG5150 before)
If it is really from regular user, then is chance that B200 is from damaged PH and very little chance, that scanner error is because of some electrical instability due to short-circuit condition in PH.
Otherwise it has damaged PH and Scanner unit, its ribbon or motherboard.
There is a chance of damaged power supply but not big, rather small.
Ł.
P.S.
Looks like big fun with repairing printers is coming :)
Sherden
Sardinia
Canon IP4300 - Epson XP-810
I just found an used IP4500. It seems it uses the same carts as 4300. Someone has any experience on it?
Is is as good as 4300?
I don't know the iP4500, but I think it was one of the last iP models to use the PGI-5/CLI-8 generation of cartridges. The print head will not fit in the iP4300. The print head in the iP4500 was originally QY6-0067 which was later replaced by QY6-0075. I don't know if this indicates that there were problems with the QY6-0067 print heads, so a replacement type was introduced?
Łukasz
Poland
iP4500 (QY6-0067/0075 gen printer) is superior to iP4300 (QY6-0061 gen printer) in terms of printhead design.
QY6-0067/QY6-0075 printhead is very similar to QY6-0059/QY6-0061 printhead but is capable of firing both 2 pl and 1 pl droplets from ingeniously designed nozzles, rather than only 2 pl (0059) or 1 pl (0061) from classic nozzles.
In practice, it nearly halves time of photo printing (compared to QY6-0061) or add 1 pl droplets for better print quality (compared to QY6-0059).
Ł.
The difference might be only the print heads used. The QY6-0061 print head has normal and light nozzle sets for cyan and magenta. The QY6-0067 and QY6-0075 print heads have normal, medium and light nozzle sets for cyan and magenta.
So I think the iP4500 might well be an improved version of the iP4300 with better photo print quality. Let's hope this one is OK.
Edit: I see that Łukasz posted while I was typing.
Sherden
Sardinia
Last update: the second second-hand MP800 that I bought impulsively is about to arrive at home.
Later today I will know if I will be lucky or if I got another expensive Knick-Knack :barnie
By the way, I am wondering if, to track the attempts to fix it and avoiding mixing topics, will be better to open another MP800 dedicated thread
...By the way, I am wondering if, to track the attempts to fix it and avoiding mixing topics, will be better to open another MP800 dedicated thread
I think so, as this will be about another printer and another problem.
I had an iP4300 and still have a iP4500, (Bought together) they only look similar that is all but the 4500 is a far better printer all round then the 4300 was, hence why I still have the 4500, it’s a real treasure..:)
Sherden
Sardinia
What about a second-hand IP5300? It uses the same cartridges
