Hobbicolors empty carts (resolved)
hazelnut
marceltho said:
Don't be afraid of purging, if you do it as I did, and that is VERY easy, and not messy at all. You will see that any dry ink will exit as well.
And you don't need the red caps if you only have one set to refill, I have a spare set, my red caps are on those.
GOOD LUCK !
Thanks for the advise I may try it out later....
marceltho said:
If Hobbicolors mentioned that the red caps were not included, and you know you don't have them yourself, you can not be disappointed in Hobbicolors as well.;)
Hobbicolors definitely did not mention anything about the orange/red caps not being included, you can see for yourself on the ebay page . They only mention it on a piece of paper included with the kit, and state that since they are used they no longer have caps, and they assume you must have some left over- I don't as the cartridges I used used tape :rolleyes:. I also ordered two sets of carts specifically so I could have one refilled ready when one ran out so I do need the caps even if I use the german method.
Just a quick note on alternatives to the caps...
I've found that electricians tape is particularly useful as an alternative to caps as it'll stretch nicely over the exit ports on the cartridges and provide a good air and liquid tight seal.
As for sealing any holes made for flushing, etc... I've found that aluminium tape is excellent for this and removes the need for a hot glue gun...
marceltho
Dutch/Living in Qubec
Never thought about just using tape for that. If you use the German methode to refill, you ONLY need red caps for storage of a spare set, if the tape works for the flushing hole, it might as well replace the red cap during storage ?
The only thing with storing a spare set I found out, you need to keep the carts standing up-right, otherwise you get an ink flow towards the sponge.
marceltho
Hazelnut
I looked on the ebay link that you gave me and it states clearly
" Please note that these OEM cartridges are used and they do not come with orange caps. "
It is written in red...
lin
marceltho said:
Hazelnut
It could be that they updated the description. You can clearly see that the listing indicated that it was revised on 11-Aug-2010 just under the 'Description' tab.
hazelnut
lin said:
marceltho said:
Hazelnut
Indeed :), Dave did update it, he accepted it was an oversight that it was not mentioned, and has now updated all pages accordingly & has also generously sent me a set of caps free of charge so, all is now well!
hazelnut
Arghhhhh :(...I spent around an hour filling all the carts with the German method, I took out the old printhead on the MP 760 which seemed to have dried ink on the bottom near the chips (presumably not good), the old carts seemed to have condensation inside also. I installed the new printhead and the newly refilled carts, went to print head alignment according to the instructions here it then went through all the normal printer actions + noises but nothing is coming out on the page! I tried a second time with manual alignment but still nothing is coming out, can anyone help please?
marceltho
Good for you, now Dave has done that, you might consider to add at the post tittle : " but Hobbicolors fixed it " as it looks negative to eveyone who sees the post title.
hazelnut
OK, done- any help with the problem above? When I tried to align the printhead it said printhead alignment failed and nothing had printed onto the page- it makes the actions and noises as if it is printing but no ink comes out onto the page.
EDIT: question moved to general forum here .
irvweiner
USA Massachusetts
Hazelnut, I think this solves your problems, it's available in your UK: Promax Imaging, they are also the rep for OCP inks. Whether you fill from top or bottom or sideways this info should help all!
http://www.promaximaging.com/catalog/ look around
http://www.promaximaging.com/products.html look around
Go here, 6th item down is what you need, I bought a bunch from rjettek in the US, about $.25 each.
http://www.promaximaging.com/catalog/index.php?cPath=29_30
Go here, 4th item down is your plug valves
http://www.promaximaging.com/catalog/advanced_search_result.php?keywords=EPV&x=8&y=19
Go the technical page, look around
http://www.promaximaging.com/technical.html
click down lower left: Canon CLI-8 & PGI-5 or just click on the link below:
http://www.promaximaging.com/PGI5 CLI8 Technique Sheet.pdf
Dnld the pdf, view the tutorial, great way to refill. Check out the parts listed to refill a cart, seal it and store it away safely.
Enjoy!! From across the pond--irv weiner
Latest posts
