Hobbicolors empty carts (resolved)
Tin Ho
hazelnut said:
Arghhhhh :(...I spent around an hour filling all the carts with the German method, I took out the old printhead on the MP 760 which seemed to have dried ink on the bottom near the chips (presumably not good), the old carts seemed to have condensation inside also. I installed the new printhead and the newly refilled carts, went to print head alignment according to the instructions here it then went through all the normal printer actions + noises but nothing is coming out on the page! I tried a second time with manual alignment but still nothing is coming out, can anyone help please?
While I was searching the archive for something I came across this thread. There is something that is worth some thinking about it.
It seems to be a common sense to do a nozzle check after installing a new print head with a set of refilled cartridges. This simple procedure ensures that the print head is getting inks and is in good working order ready for taking any command to print something. If the nozzle check tells that there is some problem otherwise, then even an alignment (some printing) should not be done. If proper ink flows are not established by the automatic cleaning cycle after the print head is installed any amount of printing could damage the print head permanently.
For unknown reason Canon printers always start with a print head alignment routine whenever a print head is installed. This is potentially a print head killing procedure. A nozzle check should be done first rather than starting off an alignment procedure. Fortunately you can stop it by pressing the STOP button on the printer if it is a multifunction printer. Or you can stop it by clicking no on the screen. Instead, invoke the nozzle check manually by yourself and check the print head first. Once the nozzle check is good then do the alignment next. By doing this you may actually save the print head yourself.
I totally agree.
Not only should an alignment not be done if the printer can't do a perfect nozzle check, if it has significant problems with the nozzle check, it's going to fail the alignment anyway, and it takes a long time.
But even if it passes a perfect nozzle check, there still could be a problem with ink flow, especially with the pigment black ink so I always print a page of solid black on plain paper to make sure there is no flow problem and then I do the alignment.
ghwellsjr wrote:- But even if it passes a perfect nozzle check, there still could be a problem with ink flow, especially with the pigment black ink so I always print a page of solid black on plain paper to make sure there is no flow problem and then I do the alignment.
Wouldnt that be even worse than printing alignment, if there is still a problem with ink flow? :|
Well, yes, but I stand ready with my finger on the reset button looking at the printout to see if it is printing solid black. What is worse is if you have the problem and you don't know it until after you do a large print job. I learned to do this when I was having problems with the pigment black ink from Inktec that had a clogging problem because it also would clog the sponge in my refilled cartridges after the second time I refilled.
