ThrillaMozilla
- Jan 18, 2011
If you look closely, it is affected, but the effect is masked by other colors. (You can also measure the effect.) Most of those bars look a bit streaky to me, suggesting generally uneven delivery in all or most of the colors. Compare that with The Hat's example, which is not just perfect, but astonishingly good. EDIT: Emulator reports that the streaks are artifacts.Emulator said:The 186 cyan strip, which requires a greater flow of ink, printed immediately after, does not appear to lighten. If there is ink starvation how is the second strip not affected?
Thank you for providing this example, though. I have never seen ink starvation without obvious horizontal light streaks. This actually looks more like what I would expect if the ink was diluted, as might happen if the cartridge had some water in it when it was refilled.
