- Thread starter
- #41
- Jan 4, 2012
- Location
- UK
- Canon Pro9000 II
Hi stratman
Yes, it is possible to enter 'Lab' values to set both white and black points. Or you can calibrate from the paper itself. I have experimented for some time, but the results are not as good as using the clear film, which appears to remove the effect from all target colour patches without shifting the colours. I am assuming it is acting as a UV filter.
The paper is listed in the signature details, PPD or Photo Paper Direct 280g micro porous glossy, it's on the web. It is a nice paper. I think it must contain a UV whitener, which is the explanation for these effects. The -97.95 value for 'b' indicates a strong response on the blue axis.
From my experiences in using SpyderPrint, I suspect that there is a software switch, which responds to high -b values when 'strip' reading over the white target patch and then offsets all patch values, to compensate for the 'blue rinse' papers. But I get better results by using the additional film. This suspected switch does not seem to operate when making individual 'patch mode' readings as opposed to 'strip mode' readings. But this is all speculation.
Regards Ian
Regards Ian
