- Thread starter
- #11
- Jan 4, 2012
- Location
- UK
- Canon Pro9000 II
Hi Roy
I have printed out the standard profile with the display environment colour temperature control set in:
1. In the fully 'cool' i.e. 'brown' postion.
2. In the half 'cool' or half 'brown' position.
3. In the fully 'warm' i.e. 'grey' position.
4. In the half 'warm' or half 'grey' position.
Rather confusingly, the descriptive terms represents the environment not the effect.
Looking at the results, they are as one would expect. The single contol does exactly what is needed, instead of having to play with multiple adjustments.
Viewed in bright sunlight, I think I would be using the fully 'warm' setting which gives the sort of result that I would judge 'neutral'.
If it were possible I would shift the whole range half to the warm direction. This rather bears out the thought that the initial profiles are too warm, (clearly designed for Rod's environment).
I think the description of the controls as a means to compensate for the display environment, led to my ignoring them at this stage, but they will be very useful in future.
Looking at the colours in the test photo images, they remain good.
I can still see my colour shift in the grey, although if I was looking at the corrected print for the first time, I might not notice it. It has however extended over the length of the print instead of the first half inch. I don't know what to make of that.
Regards
Ian
Regards
Ian
