can one make light magenta and ligh cayn by diluting magenta and cyan
This appears to be a rather long going thread already - I'm using a dilutant to make light inks for Epson printers - dye - L1800/805 or pigment inks - Pro7600.
I'm using this cleaner since a long time as a dilutant - 1 part ink + 2 parts dilutant
Thanks for that input... Interested as to why you're using a cleaning solution rather than a non-active ink base though. I'd have thought that a cleaning agent would have had unwelcome effects on the ink longevity, particularly with the pigment ink where it might cause flocculation but apparently not as you're already using it :)
For myself I'm looking at using the Image Specialists WJ807 base fluid which is effectively the same as your second suggestion and contains no cleaning agent.
1 part ink to 2 parts base/diluting fluid does seem to be the way forward though so thanks for the confirmation.
It was long time ago that I used printers like the R265 using light inks, and I was running out of them at one time.
I was using inks of the Fujifilm Drylab or Epson Surelab printers, discounted and drained from expired cartridges, those Fujifilm and Ultrachrome D6 dye inks did very well . I tested purified water as a dilutant but that didn't work well - I think that the smallest 1.5pl droplets didn't print anymore because of changes in viscosity, surface tension whatever and I tried the Octopus rinse solution as well, and it worked to my surprise. None of the possible effects actually occured to me, I was expecting similar detrimental effects as you mention them; and I was observing them over longer times - actually years, so I just use that rinse solution as a dilutant and it is working fine - for me. It's actually a kind of off-use for that rinse/cleaning solution so I'm not recommending it and refer as well to the clear ink from Farbenwerk. I was using the rinse solution up today only with Epson printers, I don't know if that rinse solution would do the same job with Canon inks on Canon printers, the 'Clear ink' is only specified for Epson printers.
