The Vivera brand has been extended to the pigment inks of HP. However, the first Vivera as appeared on the 9x and 5x series of desktop printers etc are not pigment but an exclisive dye formulation. The ones that appear on the B9180 & 8850 or 38 series of cartridges are pigment.
Omission on my part.
Tin Ho, the use of Epson compatible pigment inks in Desktop Canon printeris what I am alluding to causing the printhead to not function properly. Whether it clogs or kogation sets in you can investigate.
I can assure you that if the R1800 or R800 is used daily or regularly, it does not clog. Used infrequently, the ink nozzle will dry out and air will enter the piezo chamber and it will appear to be a clog. If further drying occurs a real clog may form, and that is the real clog from hell. This may occur if the printer is left unused for long period of time. However, if the printer was working yesterday and it is not working today. It is not a clog. There are three levels of filtration to prevent particles from entering the printhead chamber this removes the possibility of a solid impediment. these filters, cannot stop air however.
If you get a real clog from hell, it can be gently fixed by mechanical means. How? Syringe, silicone tubing and windex and finally Image Specialists Piezo head cleaner. Use this gently. This has cleared Epsons recovered from storage and junkyards sitting in the sun for long periods of time. This method is used at your won risk and no liability falls on my part. But with the requisite skills and PATIENCE. Real clogging on an Epson has not been a problem to me for the last few years. No shooting blanks.
So to answer your question about clogging? I don't ever experience it anymore. Period. Not for canon, HP or Even Epson as long as the ground rules are followed. For Epson...use regularly....No air. No clog. Oh Yeah, for Epson as well, no poor quality sponge filled cartridges infiltrated with microbubbles. You are going to experience anguish with these.
