ThrillaMozilla
- Jan 18, 2011
Blow hard on the seal. You should get nothing.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
It sounds like youre a happy refiller with the German method and good on you if it works for you.pearlhouse
So I cant resist putting in this plug for the german method of refilling. Im looking for a fast economical way of filling these things. This is why I have gone to the german method. Today I refilled 8 sets of five carts. (40) blk mag cyan yellow and two lg blk ones in a little over 1 1/2 hours using squeeze bottles.
I like this method simply because its very quick and easy with a 99% success rate and it could be better if I didnt rush it at times,You guys arnt really saying what kind of sucess rate you are getting using this method and how much time is being put into this procedure.
websnail said:...as it is silicon coated....
The word is "silicone". Silicon is the chemical element with atomic number 14. Silicone is a class of chemical compounds based on the element silicon.websnail said:...the low profile silicon plugs....
*Pedant alert*ThrillaMozilla said:websnail said:...as it is silicon coated....The word is "silicone". Silicon is the chemical element with atomic number 14. Silicone is a class of chemical compounds based on the element silicon.websnail said:...the low profile silicon plugs....
