- Feb 24, 2005
- North of Boston, USA
- Canon i9900 (plus 5 spares)
The purpose of this thread is to revive the concept first proposed in (http://www.nifty-stuff.com/forum/viewtopic.php?pid=3164#p3164) but later abandoned because we couldn't generate repeatable samples. Simply stated, the goal is to generate a catalog of CIELab colors for known inks so that we can (hopefully) identify an unknown ink by matching its color to known inks. A secondary goal is to make it possible to select individual colors from the supplier with the closest match to the OEM inks. This should give a closer color match to an OEM inkset for those who don't want to deal with profiles and are willing to run a "mixed supplier" inkset. At the very least, we would have a scientific basis for deciding which ink colors caused a color shift.
Canonfodder and I have been corresponding on this subject for a while now (the initial posts are at http://www.nifty-stuff.com/forum/viewtopic.php?pid=8159#p8159). After a LOT of work, canonfodder has developed a method for applying a known quantity of ink to a known sample size in a very uniform manner. While his method is simple in concept, it requires a great deal of skill in its execution to achieve the desired results. For this reason, canonfodder has volunteered to do all of the sample preparation and I will do the spectro analysis of the samples and post the results. Canonfodder will also post the details of his technique for those who are interested. Note that only a very small amount of ink is needed for a test (about 0.2 CC - about 20 drops), so this amount of ink can easily be obtained from even an "empty" cart or by dripping some ink from the exit of a full cart into a 1/16 ounce vial (which can be supplied by canonfodder, or ordered from www.discountvials.com). Because the ink volume is a critical detail in the test, evaporation of the water from the liquid ink sample must be avoided. A cart which has been empty and unsealed for weeks may not yield a satisfactory ink sample.
We have decided that the first inks to test should include:
1. Canon OEM BCI-6 inks. I have a set of these carts, and will supply all 8 colors (C/M/Y/K/PM/PC/Red/Green).
2. Canon OEM CLI-8 inks. Canonfodder has C/M/Y/K, but we need PM/PC. I can find PM/PC/Red/Green CLI-8 carts on the web, so I assume that they are available. Is there someone who is willing to supply empty OEM CLI-8 carts of these colors or some ink from working carts?
3. Formulabs BCI-6 inks. I have all 8 colors and will supply these inks.
4. Image Specialists BCI-6 inks. I believe that MIS sells these inks. Is there someone who would supply samples of these inks, preferably all 8 colors?
5. Image Specialists CLI-8 inks (MIS). Canonfodder has C/M/Y/K, but we need someone to supply PM/PC/Red/Green.
6. OCP BCI-6 inks. These inks aren't common in the US, but they are common in Europe. Are there any volunteers to supply these inks?
The second round of tests would include popular inks of unknown parentage. This could include Hobbicolors, G&G, and a few other popular prefilled carts. The obvious problem with these tests is that our results will only apply to the single sample that we test. Since the suppliers of these inks are unknown and can be changed at any time (as evidenced by http://www.nifty-stuff.com/forum/viewtopic.php?id=1518), this data may be interesting but it will be far less reliable than the first set of tests.
Both canonfodder and I are running with custom profiles on our 3rd party bulk inks and are quite happy with the colors that we are getting, so this project is only of scientific interest to us. The real value will be to those who want to match OEM ink colors while using 3rd party inks. Is there sufficient interest to justify the work involved?
