headphonesman
- Mar 18, 2006
I understand all of Tin Ho`s explanations of the Americam Method and I am sure they do achieve the objective of refilling the resevoir chamber.
My opinion is that this method is less easy and efficient than the German Method for the following reasons:-
The main reason of the German method was to get ink easily into the resevoir without the need to use an entry point that had to be unsealed and sealed each time a cart was refilled, i.e using an entry point that could be left open without compromising the proper cart operation.
In the American method a hole is made in the top of the cart , on the side of the partion where the labyrynth is , and for that reason must be sealed afterwards to keep the correct air balance for the cart to avoid leaking excessively. You do not need to seal the hole with the German method, sealing holes was one of the things I wanted to get away from with the "Normal method) refill hole sealed with screw/glue/etc.
This applies to "hole in the top", which ever side of the sponge/resevoir partition you go .
The majority of the ink will "drop" through to the empty chamber but some will go into the sponge and perhaps set up extra pressure if carried out too quickly, so must be done at a much slower pace.
Even the German method must be done carefully to avoid the problem, but it is less likely as 100% of the ink is definitely going in the empty compartment.
These are criticisms are being very picky , if I did not have my sharp 2 inch needles I would definitely try it and I recommend you do , to see how you get on.
I will admit that traversing from one side of a cart to the other , through the sponge , finding the reservoir hole with a sharp needle, can be a bit hit or miss....(at times.)....with a blunt needle it is much worse............but I prefer it rather than unsealing and resealing a hole.
