ip4000 not recognized.
ganguy
I cleaned the printhead, replaced it, filled carts, and went into service mode for deep cleaning. From service mode it test printed ok.
When I try to print from the computer, I get an error message "Document failed to print"
I think I'm close. Any thoughts?
Reg
emerald
Nebraska, USA
Reg: You have probably already found your problem. BUT, in case you have not; after ENTERING the service mode you must take the printer OUT of the service mode. The best way is to shut the power off, wait a few seconds and turn the power back on. When you do, the iP4000 printer will pull through a sheet of paper.
ganguy
Thanks guys, right you were! All ok with my 4000, now I've still got a bum 5000. Color won't print, (after much head cleaning) black prints wavy lines which fade in and out. Any ideas? New printhead? or is it electrical?
Thanks,
Reg
panos
Greece
Please upload a scanned image of your printer's nozzle check pattern.
ganguy
Here's some text, nozzle check follows.
Reg
ganguy
Here's the actual nozzle check.
Reg
ganguy
I should have added that I tried extensive cleaning of the print-head using distilled water, then Windex, then ink solvent. Then at least 6 deep cleaning cycles. Color won't print at all.
Reg
Good to hear your resolved your "Document failed to print" error message.
The images you posted are for a different printer and a different problem?
This is not a clog. Clogs do not have the linear regular irregularity as shown in your images.
You need a new print head and/or new logic assay board. If this malfunction is not accompanied with an error message then it most likely is the print head that has the failure.
Tin Ho
The print head is probably damaged and can not be fixed.
