How to remove PRO-1 printhead ?
Flageborg
Epson R3000
Found this piece of paper after removing the printhead......hmmmmm
Says it all.....hmmmm....sure about that?
Yes.
Unless you have an explanation how that piece of paper causes straight line ink dropouts with perfectly split bimodal hues in a single swath. We've seen this many times. This is classic electrical irreparable failure.
We are open to changing paradigms if the data is presented. This would be an exciting addition for members with similar issues to look for in the future if true.
Did you try another nozzle check to test your hypothesis that the scrap paper is the cause?
Says it all.....hmmmm....sure about that? Found this piece of paper after removing the cover....
Positive, the piece of paper doesn’t change anything.. The print head is still Fecked..
Speed on Brother, Hell ain’t half full… :lol:
Flageborg
Epson R3000
No.....still moving slow to check everything in detail and do some thorough cleaning of internal parts before re-assembling.
Flageborg
Epson R3000
YES.....hope you are right......because feeding this monster with new printhead and complete set of cartridges is money down the drain...
Flageborg
Epson R3000
So far so good......and now find some paper to prepare the Nozzle Check.......
Flageborg
Epson R3000
Nozzles did also get a dose of chemicals...
Ink was low when I got it.....and now it is only 1 more Nozzle Check printout, but will let ink use gravity until new test tomorrow.
Flageborg
Epson R3000
Cleaning the Pro 1 print head yourself is a waste of time, because the printer can do a far better job itself..
Ok....but I can do better than this ;)
