- Apr 19, 2007
- Location
- USA
- Canon MB5120, Pencil
No. Only OEM Canon. BUT, if I had your printer I would probably purchase the aftermarket cartridges from Precision Colors for their convenience as long as they are compatible with your printer model.Do you use aftermarket carts
The OEM Canon 271 cartridges are completely opaque making a direct visual confirmation of refill amount impossible. There are simple ways to get around this, such as using weights of known full and empty cartridges to compare against the cartridge in need of refilling and then adding ink to the full weight. A scale is obviously needed. Not a big deal at all but is another step or two in the refill process.
The video The Hat linked shows refilling just by adding ink until you see ink from the refill hole. The fail safe feature is you let the cartridge rest upright to equilibrate pressures inside as needed via passive dripping of ink out the cartridge. This is a common step in various other refilling methods. However, you are flying blind when refilling these opaque cartridges. On the flip side, OEM cartridges are thought to be the best for durability and function.
It should be said that there are numerous people refilling these opaque cartridges and things go well. So, it is user comfort. The process is simple and reasonably quick whichever cartridge you chose.
I would not have issue with purchasing a chip resetter from a non-Precision Colors vendor if going the OEM cartridge route. I would still buy my ink from Precision Colors and various other supplies, such as his Squezy Refill system. Not having to fiddle with syringes is a time and potential mess saver.
Concerning the "Yello Gello" situation with OEM Yellow and certain refill inks (and even water), you can avoid this by not refilling an OEM 271 Yellow cartridge. Instead, use a compatible aftermarket cartridge or a different 271 non-Yellow color cartridge that has been flushed with water and then refilled. A swap of the Yellow chip onto the "new" OEM cartridge will be required.
Refilling for your printer is simple and easy. Once you have done it a time or two you will be a pro. If you can land a plane and walk away then you can refill a cartridge..
My recommendation... IF the ARC-chipped aftermarket cartridges are compatible with your printer model then get the appropriate Squezy Refill Kit. Refill over a stainless steel sink or other suitable covered work space for easy drip clean up and obtain a pair or two of medical or medical-like gloves (unless ink stained fingers are not a concern).
