ghwellsjr said:
I can also vouch for a print head being damaged (and subsequently damaging a printer) by applying to much positive and negative pressure from a syringe full of liquid attached to the inlet ports. This caused electrical damage. I don't know about air pressure. I'm still looking for a fool-proof way to remove stubborn clogs from a print head without risking damage to the print head.
As has been stated previously, this approach is to be used only when all else fails and a clog cant be removed by normal means. However, once I got the proper screwdriver bit it is a fairly simple procedure once you get over the FUD that goes with the first time you do something new just like Panos stated. Removing the electronics and print head plate takes less than 10 minutes and putting back together takes even less time. Once the mounting nibs on the PC board are ground off, its less than a 2 minute procedure to go either way.
A few more tests were run this morning. The print head body used in the preceding posts was immersed in boiling water for 30 minutes (being careful to keep the plastic from touching the bottom of the pan by supporting it on metal spacers). After it cooled, there was no sign of distortion and the cover plate (which was not put into the water) fit perfectly back into place. This was not surprising, since many phenolics are rated for continuous operation at 250 deg F. I also checked the pieces of the raised boss that were broken off when it was disassembled, and they were all tight indicating that the glue used for assembly withstood this temperature. If a clog cant be broken free by pressure/suction alone, then I would also try boiling water.
I have also had an experience where the ceramic print head was damaged by high pressures, so the ceramic print head was soaked in alcohol for 24 hours. Using a razor blade driven into the joint between the thin and thick ceramic pieces, it was possible to break free a few pieces of the thin ceramic cover at the corners, but it wasnt possible to delaminate anything near the nozzles. Blowing 100 psi into ink entry point made no difference. The ceramic sandwich was then placed in boiling water for 30 minutes; it was still impossible to delaminate the thin ceramic plate. Finally, the ceramic sandwich was put into the oven at 400 deg F for 30 minutes. There were a few minor smells when it first heated, and there was some discoloration around the nozzle plates, but the thin ceramic plate still would not delaminate. I was trying to replicate two photos shown in
this milking post, but I had to resort to chipping the thin ceramic plate off in small pieces with a hammer and chisel. A slight amount of adhesive residue could be felt on the thick ceramic plate after the thin ceramic plate was chipped off.
This is what my ceramic piece looked like after it was cleaned up and stacked on top of a spare i9900 print head for comparison.
