Milking,
Yes I remember that photo well. Below is one that I posted recently, showing the ceramic plate from an unknown Canon print head that had two sets of nozzles for C and M to allow for 2 drop sizes. Because of the different drop sizes, this is probably from a printer newer than the i860. Note that the little caverns at the end arent included on this ceramic plate. Why does this plate not have the caverns if they are necessary to the operation of a Canon print head?
In
this thread, the surface tension of ink was measured at about 50 dynes/cm. From the large print head photo, the slots under the nozzles were scaled at about 200 microns (8 mils) wide. A slot of this width can generate up to 0.07 psi due to surface tension. Using the 10 micron nozzle diameter given previously, the nozzles can generate up to 2.8 psi, or 40 times more than the slot. These numbers would seem to indicate that the pull that the nozzles can exert on the ink will dominate over the pull from the channels. It must be remembered that the maximum actual values will be lower, depending on the surface energy of the ceramic and silicon (which I dont know). These values also depend on maintaining a continuous liquid ink link from the cart all the way to the nozzles, with no air bubbles in between.
Also, in
this post the following image was posted. Look at the upside-down cyan stripe at the bottom printed from the right to the left as the image is displayed. The middle nozzles ran out of ink before the end nozzles, not the other way around. I have seen the same thing when I recently fought with a partially clogged PM channel.
I have two problems with the overheating theory:
1. All 10 sets of nozzles were damaged, but only 8 are used in this printer. Two of these sets of nozzles were never under power.
2. I realize that many people contend that printing without ink will quickly kill a print head, but I have run jobs with over (30) 8x10 prints and where a cart stopped feeding after only a few sheets. If these print heads were that fragile, I would have blown the head, but after the cart was replaced the print head showed no signs of damage. Im not saying that we should print without ink on purpose, only that it may not be as bad as some think.
