- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
- Now have 3 Ender-3 V3 Plus SE/
Hi Samuel,
That’s great news and you now have your printer working again, but it’s not good in that the new compatibles chips should have worked if installed altogether and not given any errors, it would be nice to know what’s causing this problem.
How old is your machine, and what firmware is it currently using, have you upgraded the firmware or did the previous owner do it, where did you get the compatibles from, which site and from which company. ?
You’ll have to get onto the seller of these cartridges and get replacement cartridges or better still a complete refund because there’s no use in them sending you new cartridges if the chips have been superseded and are not been recognised.
Sooner or later you’re also going to have to tackle the waste ink problem, that 1701 error tells you it’s over 80% full, that's going to be a huge headache for you, and so are you ready for this. !
Option 1. You’ll have to send your big 70 lb machine to a service centre for them to replace the waste ink cartridge, there’s the cost of courier to and from, replacement parts and labour costs, but it doesn’t stop there because you’ll need to have at least 50% full OEM ink cartridges for them to carry out this service and system check.
Otherwise they’ll charge you for a full new set of cartridges and they have other charges and penalties and restrictions if they find you’re not using OEM cartridges.
The Pro 1 printer is really a great printer to own but if you tie yourself down to using only Canon products then it gets very expensive to operate unless you’re selling all your prints.
Option 2. You can remover the top cover and a few other parts and install an external waste in tank yourself then reset the waste ink counter to zero and never be bother with that problem again, this is a much cheaper option but this too can have consequences if not done precisely..
