- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
PeterBJ, the way I am refillin them is by a syringe and a needle, through the drilled hole on the top which I drilled myself, very slowly with no air bubbles inside the syringe, untill I notice color dripping from the bottom of the carridge, then I wipe the top and cover it with adhesive tape. I dont know the name of this method.
You are using a version of the topfilling method that is very wrong in my opinion.
When topfilling a Canon cartridge, the ink outlet must first be sealed using either the original orange sealing clip attached to the ink out using rubber bands, or using a storage clip which I find is more convenient. If you leave the ink outlet unsealed the cartridge will leak during refill.
One proper sealing method for the cartridge is first to remove the the sealing plastic ball from the factory fill hole, and after refill seal the hole using a proper silicone plug. Some newer Canon printers have very little clearance over the cartridges, so the use of a "Zero Clearance" or "Low Profile" plug is necessary. These plugs are flush with the top of the cartridge when inserted properly. Others drill a hole at the top of the cartridge and seal the hole after refill using hot melt glue. Not all hot melt glues are suitable for this, Ordinary tape is not sufficient to give a reliable seal, but a special aluminium tape might be OK. This is the sealing method I use and recommend, both plug and aluminium tape. Here is an instruction video from Octoinkjet UK, and here are links to instruction pdf's
I recommend to study this thread about topfilling and note that two different methods are used in posts #1 and #4. The method from post #4 is the method I use and recommend.
Leaking cartridges can not only cause cross contamination, but they can also ruin a print head. I have lost a printhead in a Canon iP4200 due to leaking bad quality 3rd party cartridges. The leaked ink crept under the foil at the underside of the print head and created a short circuit that took out some of the yellow nozzles. Proper sealing of a topfilled cartridge is vital.
Yes the sponges can get clogged after maybe five refills, so purging the cartridge might be necessary to restore the proper function of the cartridge.On a side note, can the cartridge's sponges be worn out from the many refills and not deliver the ink to the printhead properly?
