- Thread starter
- #21
BWlover
Sorry for the confusion... I am only using black dye ink (Inktec CLI-8 black). I diluted with 1% propylene glycol, 1% NH3 (max 5% household solution), 2% isopropanol.
If you use this ink, it turns out to have a rather warm character (a bit to the sepia side: mind you, definitely not sepia, just a bit in that direction), but the color is different for different types of paper. I already knew that there was an effect, but did not realize it was so strong. The above is on GP-501 paper. If I print on the high resolution paper (for which I have a rather odd weakness: it really like it, despite the fact it is a bit too thin for my liking; I will also try the matte paper) the tint is definitely on the greenish side.
Now my plan is too mix a bit of the BCI-6 black ink. The canon ink was definitely blueish. I hope that the Inktec ink will be either the same (than I mix it with the CLI-8 replacement ink) or more in the middle (than I don't have to mix). Does anyone have the BCI-6 black dye replacement ink and can tell you me what the color is (especially when diluted, put 'rubbed out' on a paper should also make it visible...).
I realize that if I make the 'perfect ink' (that is: the one I like personally the most - it will always be subject) it will be only in combination with a certain type of paper. BTW I am planning to go for a slightly cool tint. Perfectly neutral gray (from the gray card) looks a bit 'warm' too me: most people have this reaction. Apparently we are used to cool tint as 'gray'; could be entirely subjective also of course.
Many thanks for your inputs!
