- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
When manufactured the Canon cartridges are sealed with a vent and fill hole sealing tape and an orange outlet sealing clip. The tape and clip is welded in place most likely using an ultrasonic process. These seals are strong enough to resist pressure changes in the cartridges caused by variations in ambient temperature or barometric pressure.
As the home refiller cannot reproduce the strength of these seals using aluminium tape and reattaching the orange clip using rubber bands, the vent should not be sealed. With the vent unsealed temperature and barometric pressure variations cannot build up a pressure in the cartridge that will cause ink to leak. Due to the vent maze system the open vent will cause only minimal evaporation of water/solvents.
If you seal the vent an overpressure in the cartridge will seek the easiest way out. This might cause the cartridge to leak. I once refilled some cartridges using the German method and sealed both the refill hole and the vent. These cartridges leaked through the sealed refill hole, the vent seal was stronger. Without vent sealing cartridges refilled using the German method will not leak, whether the refill hole is sealed or not. This seems to be the same as @The Hat experienced.
I think @ghwellsjr was the first to explain on the forum why the vent should not be sealed. I searched for the explanation, but didn't find it.
