- Thread starter
- #41
- Feb 4, 2014
- Belgium
- PRO10,PRO9500II,MB5150,MG8250
Go easy on me guys, Question;- is all the Friggin around with these tests really necessary to achieve a good print on whatever paper each individual wishes to use, because for the life of me, I have never found a need to do any of this.
View attachment 9555 Borrowed Ink stained Fingers Image...
Surly it’s the subject in the print that counts and if the photo image is not good, then all these extras won’t turn a sow’s ear into a silk purse..
At the end of the day does it really make that much difference..![]()
I spend all evening finding out where the difference between my first calibration (with mostly OEM) and the last (with Octo CO) that @Ink stained Fingers found could come.
Added OEM C,M and Y (recovered from empty carts from eBay).
You can see the additional color space but not all was recovered.
Added OEM PC and PM wich only very slightly enlarged the gamut (won't show the pic).
Printed the test chart again
I do not see any difference !
I could eat the strawberries (as @jtoolman says) from every of the about 20 prints I made .
IMO this test chart lacks also large blue, green and yellow surfaces to judge.
And if I do not see - on the real print under a truelight lamp - any difference that could even so good have been caused by a slight move of a slider in the editor or a slightly different print profile or setting (let be the difference between perceptual and relative intent), how could @jtoolman and @mikling prove differences between inks this way on youtube ?
The only thing that was visible immediately after my first test was the deepness of the black (in the upper corner) between Octoinkjet Standard Black and OEM PBK.
I will keep the Octoinkjet set and buy a PGI-29PBK for the PRO-1 (this is the same ink and contains 39ml in practice 3 PGI-72 refills) and PRINT.
Ink for the PRO-1000,2000 etc is cheaper per ml but according to @mikling it is not the same ink, even not the black.
