WIN 11 migration - dinosaur printers ??
Hogwild
Canon D1350, Canon IP6600D
There are some workarounds..sort of., though not as convenient.
1. Install Windows 10 LTSC (if you have access to licensing for it). It's guaranteed to work longer.
2. Use a print server of some sort, maybe a cheap Linux box?
jimbo123
USA - NJ
MP830 MP980
good news, made some progress. was able to get a hold of a W11 laptop.
here was what worked for me:
- i downloaded the most recent drivers, some were W8, some W10
- set each up to run in compatibility mode
- run each as admin
tested using W11 laptop
- MX870 works with just run as admin
- MP980 works with just runs as admin, needed to connect USB, first, then reinstall to get WIFI
- PRO100 - not tested, but should work given that it has a W10 driver
- MX700 works with just runs as admin, needed to connect USB, first, then reinstall to get ETHERNET
i tested out printing, worked fine, did not test out scanning or faxing
was glad to find out that my horde of several 15-18 year old printers can still be used(easily refilled) and they did not become boat anchors
latest refill count is 2,153 ink carts over 18 years
J
• Active Printers: MX700(2007), MP980(2008), MX870(2010), PRO-100(2013)
• Stored Printers: IP4500, MX700, MX860, MX870, MP980
• Past Printers: MP830
• Ink: Hobbicolors, then OCP, now ASPEN
