- May 29, 2007
- Location
- Ghent, Belgium
- SC-900 ET-8550 WF-7840 TS705
You should search on "durchstich" and "Canon" and you should know that german is "Deutsch" haha
You didn't mention the time it takes to remove and replace the plug/screw in the Traditional method either.ghwellsjr said:Now if I had included the time it takes to remove and reapply tape over the German refill hole (something I believe should be done), then the traditional method will win hands down.
Hmm. If something is easier, cleaner and faster to do, why wouldn't an "expert" like it too? If your point was the Durchstitch method is simpler for a naive (never done before) refiller to begin their refilling experience, then I would agree.However, I still believe the German method is better for novices mainly because it eliminates the risk of leaky plugs and the need to buy plugs, not to mention, they don't look all that great.
The biggest con against using a sharp needle is that you'll likely stab yourself a few times during the course of refilling your cartridges. Let's just hope you don't inject any ink into yourself, or if you do, pray it isn't pigment ink.nifty-stuff.com said:I'm still wondering about the pros / cons of a sharp vs. blunt needle.
I was a little too brief in my description of what I did with the traditional method, I merely referred to the process described in posts #4 and #6. In there a reference is made to the Hobbicolors instructions which include drilling the refill hole and plugging it with one of their plugs. I did measure the time it takes to drill the hole the way they describe (1/8 inch drill, hand-held with a towel and twisted into the 1/8 inch depression over the reservoir) and the time it takes to insert the plug (since I didn't have one of theirs, I used a different one but the time would be the same). For the whole traditional refill process, I included the time it takes to snap on the orange G&G clip over the outlet port and the time it takes to remove the plug and re-insert it at the end.stratman said:You didn't mention the time it takes to remove and replace the plug/screw in the Traditional method either.
One of the things I have been promoting on this and other threads is the use of Inktec inks supplied in the small syringes. This seems to be the only way to buy Inktec ink in the USA. This, of course, applies to both the traditional and German method. I advise people to only refill the cartridges in their printers, in other words, don't have any spares, and refill (or top off) all your dye ink cartridges whenever any one of them registers low (empty reservoir). Refill just your pigment black when it is low.stratman said:If something is easier, cleaner and faster to do, why wouldn't an "expert" like it too?
