- Thread starter
- #11
- Nov 27, 2010
- Location
- Copenhagen Denmark
- Canon MP990
Thank you very much. I'll order the 1TB EVO drive then.
Depends on whether Microsoft somehow blocks your country from using the Tool. I can do it here in the US. Since you can choose language during the install you should be able to download the Media Creation Tool from USA servers in your country. But you won't know till you try. Read all the three links here to see requirements and instructions on updating as well as obtaining the Tool.so the free upgrade should work or what?
It has been possible in the past and still may be so. The following link details the procedure as of December 2018.I wonder if I can install Win 10 on an empty HDD if I enter the Win 7 key?
I have read it is pretty much the same as with 8.x. Don't know about 7, though. Changing or adding drives, RAM, and video card are usually no issue. The biggies are CPU and motherboard that are connected for the activation / ID process. A call to MS can often result in joy depending on your explanation and the person you talk with.with Win 10, the license is much tighter linked to the specific hardware the installation is done on the first time.
That's what I have done, albeit without having to enter ANY key. The licenseI wonder if I can install Win 10 on an empty HDD if I enter the Win 7 key?
This would apparently not apply to separately-installed operating systems.If you choose to upgrade from Win7 to Win 10 the proposed way, please accept that you cannot run your old Win7 system anymore from a mirrored/restored system disk. The registration key won't be active anymore on Win 7 in that case, it has been used to verify that you have a valid key, upgraded to Win 10 in this case.
