- Apr 19, 2007
- Location
- USA
- Canon MB5120, Pencil
Excellent info. Thanks Peter.
My thoughts...
BTW, Speccy and Belarc Advisor are very similar in reported info.
One thing in Speccy's favor is that there is a portable version which does not require installation. While standalone apps, such as ProduKey, which are only a single executable file requiring no installation are my favorite kind of utilities, a portable app that only requires copying or unzipping files into a folder without installing are my second favorite kind of apps.
A selection of portable apps here.
My thoughts...
As you suspected, this computer's appears to have the Product Key stored in the UEFI, so no need for you to manually enter it in when clean installing Windows 8 or 10.I could do a clean install of Win 8.1 on the new and empty SSD. I was never asked for a key.
Once this computer was upgraded to Windows 10 then the Product Key from Windows 7 was converted to a Digital License and that license stored on Microsoft's Activation servers. No need to re-enter manually the Key/License if clean installing Windows 10 again when changing the hard drive to a SSD. You might have an activation issue if you change out the motherboard and/or CPU as this is an OEM copy of Windows. In that case, a phone call to Microsoft may allow for activation as long as your explanation is proper, ie you are not using the license in another computer altogether and the tech you speak with is not too grumpy.It came with Win 7 Home Premium 32 bit. and has twice been upgraded to Win 10
If I understand correctly, you were installing Windows 10 on a formatted , ie empty, hard drive, that once contained Windows 7. If you had merely upgraded from an intact Windows 7 then you would not have needed to enter a Product Key as the installation routine would have found it in your Registry and completed activation without any further input from you. If you were still using Vista then you would not be able to either upgrade or clean install since a Vista Product Key is not accepted by MS to exchange for a Digital License, which is needed to activate Windows 10.When upgrading to Win 10 I installed the OS to the harddisk I had formatted. I had to enter a key and the key I had used when I upgraded it to Win 7 from Vista was accepted and the Win 10 install started and Win 10 is activated.
In this case, the Windows 7 Product Key was not in the UEFI and so you had to manually enter it when installing Windows 10 on a formatted hard drive.I installed Win 7 on the laptop and later upgraded it to Win 10. I installed Win 10 to a formatted harddisk and had to enter a key. The Win 7 key I had used was accepted and Win 10 is now activated.
I had forgotten my old friend Speccy. The "Serial Number" Speccy reports for the Operating System is different than that shown by the other apps I've reported in this thread, which all show the same Key.
