Hi avpman,
yes that is the disadvantage of this system: reset is for all cartridges at a time. It would be nicer if you could reset one cartridge at a time, not all cartridges together. However, since there is so much ink inside (about 110 ml) you could easily give it a reset when one cartridge runs empty and refill after the printing job.
The design of the cartridge makes it very easy and quick to refill. Wait a few minutes for depressurization of the cartridges, carefully give the plug a twist, wait a minute before opening and pour your ink in it and the semi-transparant wall will help you to determine how much ink you must pour in. If the cartridges are completely made of a dark material this would be impossible to achieve.
The resetter is especially designed for the Epson BD500DN/B300DN printer, but works also for the Epson Pro 3800 original cartridges chips (if they are not below 5 %) and the maintenance tank chip. Be warned: if the level of the chip falls below 5 % it can NOT reset the chips !!! I did discover it with my LK cartridge (light black) which prior showed the warning: "not enough ink, exchange the ink cartridge". All other chips were only showing low and were flashing on the printer display screen. Eventually you could obtain these cartridges and use it with this particular resetter and forget the two control chips if you want to reset and refill one cartridge at a time when it runs low, but be aware this must be done when it shows low only, not empty.
You can purchase it at:
http://www.szmegacolor.com/sdp/1042...ter_for_Epson_3800_3850_3800C_OEM_cartri.html
Unfortunately it is quite expensive.
