Why is it, that so many people seem to like to create unnecessary arguments using "hear-say" reasons if they do not have proven first hand experiences with the cartridges (show me the pictures, like I do and have several systems tested first hand and tell both the advantages and disadvantages of the available systems).
Is the Inkrepublic.com's Pro 3800 I-refill system the best for everybody ? Not if you do not like to have the cartridges sticking out from your printer and forces you to remove the ink cover. The strange resetting procedure is something which is to be improved so you can actually reset one cartridge a time when it runs empty, not all cartridges at the same time like this one. Nor the fact the cartridges should be refilled when the ink level has reached a minimum level to prevent air being pumped into the system. The main reason I favor the Inkrepublic.com's system is that not only can reset the maintenance tank when it get full, but also the ease of refilling and most importantly the building quality is far superior to any other refillable system (also the ones from Colordroplets.com and the ones from Efillink.com, the last one happens to be same as the one sold by Inkjetfly.com and ink2image.com). The sealing of the ink entrance valve is very sturdy and rigid like the original Epson cartridges.
My previous Colordroplets.com cartridges do work very well, but not after consecutive refills: somehow the rubber sealing suffered from material fatique (or rupture) and the ink was pumped through a leak into my printer, making a complete mess and letting my LM cartridge be drained.
The similar built cartridges from Lyson and other manufacturers do feature this flimsy rubber seal and from my own experiences this is not good on the long term as stated by the comment by ink2image.com: "...The
Ink2image cartridges can be refilled many times but will eventually show signs of wear at the ink
exit port seal. Replacement cartridges are available at the low cost of $ 20.00 each when this
occurs...." Well for me it already was after 2 refills, so for me it was Murphy's Law.
The bladder-based refillable cartridges of Inkjetfly.com/Ink2image.com do have an important advantage: the superior constant ink flow over time and the fact action of air is reduced to a minimum as the bladder is pressed together during printing. This is the system that mimicks the original Epson cartridges with a inkbag on pair. The procedure of refilling the cartridges: continously pushing and pulling the syringe into the cartridge, puts extremely stress around the rubber sealing in a very short time period and will shorten its life.
My favourite cartridge would be a system using the bladder-based design combined with the sturdy and rigid ink outlet valve similar to the original Epson cartridges or the Pro 3800 refillable system's sold by Inkrepublic.com/Inkjetcarts.us/Conecolor.com. And it should be capable to be reset per cartridge a time when ink runs low, not all at a time like my current system or the ones using the so-called autoreset systems (Lyson, who warns specifically to check ink levels periodically and before a large print job as the ink level is reset to full every time when the printer is turned on). Well fortunately the maintenance tank is now resettable using my reviewed blue resetter, but it must not be below 15 % or an error message will be shown on your printer display.
In the end there are only a few different designs for refillable Epson Pro 3800 cartridges.
So every system has its merits and also its disadvantages and when I consider all these facts, the current system from Inkrepublic.com is way better than the other systems from my own experiences. It is now running for more than 2 months effectively and without any major problems (besides a DOA photo black cartridge with a leak in the pressure system which I had replaced soon, causing gradually nozzle loss in the nozzle check print).
Just to clear things: I paid several hundreds of dollars in more than a year time to have these cartridges tested by myself, so consider me as a self sacrificing guinea pig undergoing an expensive experiment and I hope the pro's and con's of this topic will show respect to my neutrality based on my own experiences.
