Same type of Canon ink for different Canon printers - or not?
Swordfish
Stockholm, Sweden
canon ip8750 and G 3501
Hi all !
Is it possible to use the ink for e.g. Canon G3000 series printer and fill cartridges for a Pixma ip 8750 printer? The G3000 series uses GI-590<-> ink which is less expensive than Pixma CLI-xxx ink.
@The Hat with the speedy answer for the win! :clap
I was busy looking up the inksets while you snuck in. ;)
The rabbit may have been first to post but the tortoise wins the race.
Inks used with the IP8750:
The dye-based inks (C, M, Y, GY and BK) produce stunning quality colour photos while the pigment black ink (PBK) is used to create documents with crisp, sharp text. Genuine Canon inks feature the ChromaLife100+ system, producing photo-lab quality photos that can also last a lifetime.
The GI-590 are not only an incomplete set of colors needed but also inferior archival capability compared to the inks used by the IP8750.
Yes, you can use the Dye-based CYM inks and the Pigment Black ink of the GI-590 inkset, but what to do about the Dye-based Black and Grey?
Consider the GI-23 inkset (or whatever the equivalent model number in your country) that has all the Dye-based ink colors the IP8750 requires and uses ChromaLife ink set. It's not the ChromaLife+ used in the IP8750 but it's better than the GI-590 non-ChromaLife.
https://shop.usa.canon.com/shop/en/catalog/gi-23-black-ink-bottle#
PS You do not need the GI-23 Red ink, so buying a multipack would be a waste.
Swordfish
Stockholm, Sweden
You also forgot to mention that @Swordfish can get all these inks direct from the Canon website with free delivery.. while also protecting his print head from damage..;)
Hi, I am back, still alive! :) Sorry for my very late feedback.
My question was to refill the ink tanks for the PIMXA printer IP8750 with bottle ink of same quality (ChromaLife) or almost the same.
IP8750 is using Y, M, C,GY, BK dye ink and PBK pigment black and ChromeLife100+ system.
Can I replace YMCGYBK with GI-53 (GI-23 seems not to be found i Sweden) wich has all the dye colors? But what to do with pigment black?
L805, WF2010, ET8550
Canon is using different names for the inks in different business regions - GI53 inks are the bottled Chromalife inks for the G550/650 printers in Western Europe.
There is a separate series of Megatanks printers running with pigment inks - with the GI56 inks for the GX-4050 - 5050....... printer models.
