Refilling empty cartridge?
Parhs
I dont know which vendor to chose. I dont trust OCP as i got 100% clog at another printer.Websnail didnt respond to my email about to try a newer batch... There is a local InkSpecialist ink vendor here i might try this ink. Do you have any other vendor to suggest?
panos
Greece
I understand you live in Greece.
My current dye inks have been imported from China and it was a risky process as the customs had threatened to force me to pass them through an expensive National Chemistry check. I can't recommend this to anyone living in Greece.
However I am very satisfied with inkline.gr (I know of people who are being supplied for more than 7 years by them and I am also using their pigmented black for the last 4 years without a clog or any starvation issue). Also, I would consider perfectprint.gr as well -- I found them on the web while searching for an answer to a forum member but I don't have any real experience with them. However they seem to know their stuff very well.
Parhs
Inkline.gr guy doesnt actually have a store as he cant give receipts. However he didnt tell me the ink brand. My experience with him for HP inks was not so good. I got clogs after a while. 0 ink flow. ImageSpecialist supplier ininkjetphoto.gr (he doesnt tell either but it is obvious)that i have suggested to two people with HP carts had no problem! http://www.eurojet-melania.gr/ has OCP ink but resulted in clogs ,not only for me but for everyone i suggest them to try it.
perfectprint.gr i see that it has cheap inks but has the same ink for all canons.That doesnt seem good.
As for customs you should do somehow self-import otherwise cost is too high.
So i am going to try from inkjetphoto (cheaper for 1 bottle) and when other inks run out i'll order from octoink.
panos
Greece
That's great. Please post your impressions with the inkjetphoto ink when you use it.
Not sure if/how I've overlooked it but if you could PM me the contents of your email I'll make sure I get back to you.
Cheers,
Martin
Parhs
Here
my last nozzle check,almost perfect.
