Refilling Canon with OEM ink
@martin0reg, Now that you have concluded your test prints for the year, it is surprising all dough your samples have had some fading and colour loss in all of them, they are still quite acceptable in their own right...
martin0reg
Germany Ruhrgebiet
Okay, you may call it "lively sepia"...
but I wouldn't be so kind. Perhaps because I'm looking at the real print.
Take a look at these crops:
martin0reg
Germany Ruhrgebiet
25 days under the UV lamp, AldiSihl glossy paper.
Fotonic XG used in a ip4000 and in a ip4500
Amazon "patronenland" cheap compatible cartridges and canon BCI-1411 (LFP cartridges)
Different starting points, so only compare the actual fading difference of each pair, not the results of all four samples across (as usual)
My favorite refill ink for now is canon OEM out of big BCI-1411 cartridges. This ink is clearly NO chromalife, but while it is fading, the color shift seems to be the least of all.
martin0reg
Germany Ruhrgebiet
Three of the "better" canon refill inks from previous tests,
now after six weeks under the UV bulb
(B&W print using all color channels)
None of them can compare to canon OEM carts "chromalive".
But this time BCI-1411 looks best to me..
- canon BCI-1411 (LFP carts)
- canon bottled GI ink
- fotonic XG
Just for comparison I had fuji DL under the same bulb, sadly NOT for use in canon thermal printheads
that's quite interesting, even for an Epson user...life is not easy for a Canon user in search for the most UV stable ink aside from the genuine Chromalife version, it's a pity that the choices are that limited
martin0reg
Germany Ruhrgebiet
Since easter I run a sort of crossover test, with six different inks from dye to pigment:
Printed with canon pixma's (chromalife+, BCI-1411, canon "GI" bottled),
epson r285 (fuji DL dye), r800 (IS compatible pigment) and 3880 (ultrachrome K3 OEM).
All on the same paper (aldi/netbit glossy 300g). Mostly with more or less precise profiling - only the print with canon OEM carts was not profiled, therefor the bluish cast.
Scanned as usual, two pairs of exposed and unexposed each, makes three scans,
all with the same setting of the first scan:
1 canon OEM chromalife+ cartridges (dye) and epson ultrachrome K3 OEM (pigment)
2 fuji Drylab ink (dye) and epson ultrachrome high gloss compatible from IS (pigment)
3 canon BCI-1411 (dye for canon LFP) and canon GI-490 (dye for canon CISS printers)
[above is unexposed "UV1", below is exposed "UV2"- from which I cutted off some overlapping areas]
I was expecting worse results... is my desert bulb getting weak..?
Well the best dyes by far are canon OEM chromalife cartridges and fuji DL, that's no surprise. But could these best dyes eventually compete with pigment?? The most professional tests by aardenburg or wilhelm would say: NO... first of all because they are testing longer exposition.
Looking at my samples I think dye prints could compete - not for decades but for years - and only with a few sorts of dye ink... (even fewer if you want affordable dye ink)
IIRC the desert lamp is a CFL? Fluorescent tubes change their spectral properties with age. But maybe the lamp is OK and the inks better than expected?
You could test the lamp by redoing a test of an ink set with known bad UV fade resistance
martin0reg
Germany Ruhrgebiet
Yes it's fluorescent type, brand "exo terra", like this
Maybe my second bulb has smaller range of UV-B. But these tests don't claim to be scientific, just like other real life tests behind a window or on the balcony.
But I really think it's due to the ink types of this latest test, which makes the results look better:
The first and second scan is pigment vs the best dyes, only the third scan shows dye inks which are fading similar to most other canon compatibles.
PS: BTW in scan (3) you see the same greenish tint of the faded "GI" print, compared to the evenly faded "BCI" print, that you noted looking at the B&W samples.
So our tests may be not scientific but nevertheless with some consistent results
(just like ISF says below ... while I was adding my PS..)
I think part of the problem is that we cannot separate the effects of UV and ozone, there may be more ozone outside than under your lamp, and the GO overprint, or the scotch tape don't filter the UV but close the paper surface against ozone, and doing just UV under a lamp may give different results to a mixed UV/ozone exposure outside, we just don't have the rescources available to separate those effects as Wilhem Research or Aardenburg can do in their labs. But overall I think we got quite some information from our tests to confirm some more general rules beyond a specific ink/paper/printer combination over the last years.
