- Oct 27, 2005
- Location
- South Yorks, UK
- Epson, Canon, HP... A "few"
Catching up again but a few things.
1. The theoretical "never have to reset" pipe dream is, I'm sorry to say, about as likely as myself becoming a TV celebrity and winning the lottery. I'll place a £100 wager on that right now. It has been theorised in the past and something I confirmed when I was looking at homebrew Canon CIS systems with the CLI-8/PGI-5s. All we found then was that the firmware and/or chip logic ensured that it would recognise that it shouldn't still be able to print significantly more than the cartridge could possibly hold and would indicate a faulty cartridge/chip. I'm serious about that bet by the way, with any proceeds to the Red Cross (I'm not paying your beer money
2. I can confirm the inclusion of "Setup" marked cartridges with the EU model I have and absolutely no difference in behaviour compared to the "Setup" cartridges being used in 550/250 & 551/251 models (like the iP7250/iP7220) where there are physical differences in design. Canon obviously didn't see any point in p*ssing off their more experienced semi-pro/pro customer base by sending out piffling limited cartridges... Discounts and offers in the USA not withstanding.
3. As noted numerous times before now, the resetter issue, as far as ink monitoring goes, is only significant now if you have DIM'd your cartridges. I'm pretty sure we've now thrashed this to death and common sense indicates that with the resetter now available as standard with any refill inks it's unlikely to be an issue except for early-adopter refillers when the early inkset(s) appeared pre-resetter or those buying from Chinese inks purporting to be Pro-100 type with instructions to DIM as part of the refill process.
The obvious solution and/or work-around is frankly to get a new set of cartridges. Not cheap but it does the job.
4. The new wrinkle from Bithead is however a significant development and will undoubtedly be of interest to the REdSETTER folks. BUT I would note, Canon have every right to expect that be left alone as you're crossing into a legal quagmire and out of the "legitimate use" realm of ink monitoring and refilling. By faking the OEM label I would expect a legal challenge based around charges of software/license infringement.. something which, I for one, would not wish to invite.
