Instead of resetting chips, I am thinking of the creation of an accelerated printer use device.
This device will work in conjunction with ARC or so called COC chips which are supposed to reset themselves when empty.
Background: the major incovenience of ARC chips is the domino effect of being empty as each becomes empty and needs refilling. This can be frustrating and time consuming.
Solution: If we are able to force all these ARC chips into an empty condition at the same time, it has the same effect as a reset mechanism as provided by previous resetters. The reset algorithm would still remain on the ARC chips just that this device simulated accelerated use on each chip to the point they would be empty.
Benefits: Less ink wasteage, more convenience and use of clear side aftermarket cartridges.
Applicable to all brands that use aftermarket ARC chips.
