Pixma Pro-1 B200 error
skid72
Canon pixma pro-1
Some pictures of the box
Thanks for the Pics, but one would have done, still… :celebrate
But in the meantime do you have any error messages showing before you start, if not then keep the printer powered off and plugged in the power socket.. I’ll PM you later..
skid72
Canon pixma pro-1
Yes you are right. The most important picture has to be done. ;);)
I've the errore 200. The printer Is off and plugged in the power socket.
Thanks for tour help.
Ops’ now you’re in trouble if you can’t clear the B200 error, because you can’t change the head with any errors present, you’ll have to clear that error or face a bigger problem.
Try removing the power cord and leave the printer sit for several hours, afterwards put the power cord in the wall socket, open the top cover power on the printer and see if the error is still present, hopefully it will clear..
skid72
Canon pixma pro-1
The simplest solutions didn't work, so I removed the top cover following the instruction provided by "The Hat" and then I've had access to the printer head. I unlocked the printer head from its parking position and then I've replaced it.
After remounting all the parts and wainting several minutes "to purge I think", the printer came back to life. :)
I'm very happy and I want to say a big thank you to "the Hat".
A nozzle check is attached.
