The solid tubing slips into the flexible tubing to give it some support to easily attach. The Aquarium tubing goes over the inlet port.
Some of the cyan nozzles in my printhead may be clogged for over 2 years. What might an appropriate period be to let my printhead soak in unclogging solution? A whole day, or a couple of days?websnail said:Something that hasn't been mentioned in all of this but relevant is the "Patience required" aspect...
If the printhead in question has been sat around for ages or has developed a complete clog (like the infamous Yellow incidents) then an appropriate period of allowing things to soak is definitely required.
One of the biggest causes of failed printheads and/or cleaning attempts is impatience.
I had a CX6600 that had been sat with its durabrite pigment "clog me silly" ink in it for nigh on 18 months and that required 2 days and a few pad changes... Cyan Dye ink is a whole different beast and easier to shift... I'd say you're looking at 24 hours but be prepared to repeat as required.inkoholic said:Some of the cyan nozzles in my printhead may be clogged for over 2 years. What might an appropriate period be to let my printhead soak in unclogging solution? A whole day, or a couple of days?
Good to hear there's still hope for the old lady. What do you mean by pad changes? Folded paper towels that are soaked with Windex?websnail said:I had a CX6600 that had been sat with its durabrite pigment "clog me silly" ink in it for nigh on 18 months and that required 2 days and a few pad changes... Cyan Dye ink is a whole different beast and easier to shift... I'd say you're looking at 24 hours but be prepared to repeat as required.inkoholic said:Some of the cyan nozzles in my printhead may be clogged for over 2 years. What might an appropriate period be to let my printhead soak in unclogging solution? A whole day, or a couple of days?
You can't hurt the printhead by leaving it in the solution for longer so being extra patient just helps that bit more.
Sorry... just seen this... Yes, that's what I meant...inkoholic said:Good to hear there's still hope for the old lady. What do you mean by pad changes? Folded paper towels that are soaked with Windex?
