- Thread starter
- #11
- Dec 27, 2014
- Location
- Germany
that's one possible option - you can use the black channel and print with the driver option 'BW print' which does not use any of the CMY colors. I did that with an WF2010W for testing, but that's limited to A4.wouldn’t it be better to put gloss optimizer in a set of dye ink carts on a lower end printer and use that to apply the gloss optimizer over the whole image..
But the first question should be whether the gloss optimizer is needed at all - most likely not as long as you use OEM inks on OEM paper, lower cost 3rd party consumbles may require you to compensate detrimental effects - bronzing etc - for which you pay with additional handling time , the gloss optimizer and potentially another printer. I think it would be better to use OEM dye inks which are affordable and don't need any addtional processing. It's the paper at the end making the difference in longevity , There are various Epson Claria and Canon Chromalife tests with dye inks which excel in corresponding tests with pigment inks
https://www.printerknowledge.com/threads/do-pigment-inks-fade-slower-than-dye-inks.15466/
And there is no reason to believe that 3rd party pigment inks perform even as good as the corresponding OEM inks.
