- Jan 6, 2011
- Location
- Jordan
- Canon MG5640, iX6840
I am not know if above posts mean all canon cartridges, the optical sensor exist in all models like I have and with same functionality?? ?
Actually Mike, we've been running into this problem with our fleet of Pro-100's since we started to refill the tanks before they were dry. I use a Redsetter BTW. What's better is just to visually check each tank and change them out before empty if possible, then reset and fill to the top. We've dramatically reduced our fried head collection since adopting this protocol. once in a while I have to pull a head and then with some of Pharmacists solution, gently pressure clean each colour channel on the head. I use a big syringe with the tip cut to fit snug over the ports. Works great!
Roy, there is a trick that you can use the overridden chips to advantage. As long as the carts are topped up occasionally the last step before the warning the levels will "stick" there....This is a way to get around resetting unless you go dry in the reservoir. I experimented and proved it three+ times and was the start of understanding/keeping an eye on how the optical system actually works. The last step as it turns looks to be the point of entry of the window. Now what is interesting is that on a normal chip, the chip will continue to empty, regardless of the top up. On the Pro-100 the overridden chips does not go down to empty until transitioning the optical detection. Why???? only Canon knows. Actually redsetter does not know either...so really nobody really knows except Canon.I had exactly this problem when I started refilling my pro 100. Because at that time the resetter was not available and I had to override the Canon detection system. When I eventually got hold a a resetter this set of Carts, always displayed incorrectly.
I wrote many message on this board seeking some sort of guidance, but it seems nobody else had the problem. This was a few years back.
rs
One thing is to weigh the empty cart and the cart when refilled and check if the cart has enough ink.
I have not been able to determine at exactly what point the optical sensor is turned on. It might be 60% or 50% empty.
This seems to be discordant with what The Hat posted:
I can imagine there are other values assigned that I have not observed, for example they may assign a value for a cart tagged as; “ink monitor disabled”.
The Ink Level display on my implementation is slightly different to Drjim, in that mine shows 4 ink tanks on the left and 4 on the right, whereas for Drjim it shows all 8 in one single column.
Also, for Drjim there is a noticeable demarcation line in the graph on the top 4 carts, but that may be because those 4 carts are relatively full. My carts were either full or near empty and the ones showing near empty have “feathering” of the graph.
