- Apr 19, 2007
- Location
- USA
- Canon MB5120, Pencil
The purge system uses a pump to create suction in the tubing that sucks waste ink from the print head (and cartridge) to the diapers in the bottom of the printer which absorb and retain this waste ink. An airtight junction between cartridge and the parked print head would facilitate this process.
Flooding the purge pads with solution is the test. Anecdotal evidence suggests that whether the print head or cartridge is clogged has little or no bearing on whether the flooded purge pads are drained. It also seems that little or no ink is drained from the print head in this simple procedure since the purge pads will begin to whiten, suggesting only the flooded solution passes through the purge pads. Of course this may only applies if you merely close the lid, let the printer noise finish, and then reopen the lid, ie NO cleaning cycles or printing done, but you can try whatever you'd like to compare results. AFAIK, no one has witnessed and reported the exact moment the flooded solution disappears from the purge pad of a properly functioning printer.I couldn't have any proof that I fixed it.
