Colormunki Photo device and ccStudio
@The Hat - thanks for the link but those are more expensive than the Chinese ones; and I'm not clear yet about the electrical rating - 3 V or 5V and the power; I'll see.
Your Aliexpress links don't seem to work anymore; I currently don't need a lamp for repair but just as a backup.
I'm currently trying the 'made-in-China' link
"I currently don't need a lamp for repair but just as a backup."
Same as me, you need to have to compare to something, so getting a working lamp is most important until you have a working unit.
If you put the search term LNS BP310, BS H1 Pentax into aliexpress it will provide 2 items
Price is about 14eur + 10eur shipping
https://vi.aliexpress.com/item/1005005964086236.html
https://vi.aliexpress.com/item/1005007932437288.html
The Other lamp RIESTER 10605 2.5 0.75A RI MINI
Searched for "RIESTER 10605" give this
compatible
https://vi.aliexpress.com/item/32544956289.html
original €55.69
https://vi.aliexpress.com/item/1005003208945590.html
However this has a base no just 2 wire you can easily solder to replace old bulb.
Removing the lamp from this original base can be a challenge if it is properly glued.
(need to use a dremel and cutting disc perhaps.)
These lamps are quoted for 2.5 Volts, previous lamps with 3 V, and the overall power is unclear at this time. I opened an i1Pro longer time ago to check how the UV filtering is done - with a ring UV filter in the light path for those spectros to do M2 measurements.
I'm currently waiting for feedback for the 'made in China' offer which by the description seems to be the most compatible lamp.
