Trigger 37
- Dec 23, 2006
Hello to all,... just a word of caution on the cleaning solution. I saved a printhead the other day by installing an ink tank that I had filled with commercial head cleaner and it worked great. Took a little time and several prints but it finally worked. I was so impressed with the results that I tried it on another machine that was very clogged. The mistake I made was that I printed half a page of data before I ever got decent results from the nozzle pattern. I had no luck with any black ink at all when I tried to print half a page of full black,... not a drop of ink. Tried it again and "Bang", the printer came up with error message, "Please Wait,... Printhead is Cooling". Well it never cooled off. I'm afraid I burnt it. The obvious problem is that the printhead was totally clogged or the purge unit could not prime the printhead. In either case ( and I still don't know which) there was no ink in the printhead when I tried to print half a page in solid black,.. and I did it twice.
So you can't just use an ink tank with cleaning solution until you are getting some kind of ink flow and have the printhead primed. Otherwise, you could have a big problem. I will be really sad if I have "Fried" that printhead. The printer in question is an MP730 and I suspect that the purge unit is so clogged that it can't prime the printhead. I still have a lot of work to attempt to clean out the purge unit and retest. If that doesn't work,.. there is a big job ahead to take the MP730 apart and get at the Purge unit.
