How to dry ink printed on back of photo paper
JustCharlie
Epson 600's, 2200's, ALPS, +
Or you switch over to a printer which meets your requirements - the already mentioned Frontier DL650 printer , the printer does backside printing on media which are suitable for that printer
Just look for the specs
Back printing Two 40-character lines in backside print of information
on
https://www.fujifilm.com/de/en/business/photofinishing/frontier-dry/dl650-pro/specifications
Not sure about the DL650, but Fuji had always used an Epson dot matrix printer inside the
paper feed track.. typical receipt type printer with an ink ribbon cartridge.
brwinters
G7020, G620, iP100, Pro-2000
The DL650 has a twin dot matrix backprint unit, yes. Last I looked, it's also minimum $1k used and takes up a lot of space, and very difficult to ship.
JustCharlie
Sorry.. I wasn't suggesting installing one, just that this is the ink that's used and it doesn't smear on the back of the print.
brwinters
Oh I see. I imagine there might be some special formulation in the ribbon to stop it smearing perhaps, or at least a different one to a generic ImageWriter ribbon anyway. Other possibilities are that the Fuji paper backing is specifically receptive to the wax/ink in a way that other papers are not, or that the heater unit plays a part in the matter.
JustCharlie
I'm not really sure.. I haven't seen a Frontier since the first ones came into the US, but those were wet process RA/FA type photo papers and the backprinting held up just fine in the various tank solutions. And the paper moved into the developer after only a few seconds, so the ink had to be dry almost instantly to avoid any sort of contamination. It makes sense that they'd continue using the same unit in a dry process since it has a good, long track record. So we know the ink would work.
But as you mentioned, not very practical to install on an inkjet!
Smile
Europe EU
Just use hair spray before printing, afterwards you can add another coat, this can work or not depending on ink.
brwinters
I'll give it a shot
