- Apr 19, 2007
- Location
- USA
- Canon MB5120, Pencil
The nozzle check from your post #34 is missing. Did you delete it?
Your latest nozzle check with the new inks looks pretty good. The PGBK latticework is only partially printed and needs attention. At this point there is no reason not to think you can return to good function.
There are a number of way to approach the PGBK issue. For instance, you can do a Regular Cleaning of the PGBK and then a nozzle check to see if improvement. Repeat one more time if you would like. At that point you could let the printer sit over the evening and then try another Regular cleaning and nozzle check the next day. Post results.
Alternately, you could do a Deep cleaning once, do a nozzle check and then wait overnight as per above. Do a nozzle check and post results.
If you want you could flush the print head under tap water till running clear or thereabouts and then soak the print head with warm water and couple drops of Fairy liquid dish washing soap. Change the water if significant colored or every 4-12 hours. What ever you want. There is no prescribed way. I would place a crumpled up paper towel under the print head in the bowel and pump it up and down at water changes and whenever I wanted to help move the liquid into the nozzles. Flush and soak for as long as you can stand it and then a little longer, maybe 2-3 days or even a week. It's entirely up to you. When done then flush the print head with tap water or distilled water and let dry over night. Any liquid on the PCB board of electrical contacts may cause a short and ruin the print head.
To improve the quality of the scans of your nozzle check follow the instructions on scanner settings here:
https://www.printerknowledge.com/th...canon-nozzle-check-using-a-cis-scanner.11398/
Cropping is done either within the scanner software or with a program like Photoshop, the free windows Paint, or any other number of image apps.
