ThrillaMozilla
- Jan 18, 2011
Oh, dear. I suppose it depends on what you have available, but that's a pretty drastic way to solve the problem. It leaves with a lot of fluid (water +? alcohol) in the cartridge, which will dilute the ink somewhat, unless you can dry it (are you sure it's really dry?) or you flush it again.Redbrickman said:I ...ended up with a cart too full and ink in the maze. If that happens best plan is to suck out as much of your precious ink as possible with the syringe/SquEasy bottle, then flush the cart.
Ghwells has dealt with this problem hundreds or thousands of times. Just draw a little air through the maze. Or some people blow into the vent if you have no way of drawing air. I like to also add a drop of water (or water-alcohol mixture in the case of pigment ink) to the vent, to clean it as well as clear it. This might dilute the ink a tiny bit at the top, but it's nothing compared to flushing.
