ThrillaMozilla
- Jan 18, 2011
You're correct that it works 100% of the time for most people. I'm simply telling you that if you drill the hole above the opening, it cannot leak in normal use, but if you drill it lower, it might under some circumstances. As I say, continue what you're doing, but if someone experiences a leak, you'll know what could cause it.marceltho said:I have completed your drawing, see below. I added the ink outlet, and if there was a POOL of ink, it would come out of the outlet as well, but it is prevented of doing so by the lack of air above the ink in the ink chamber.
I'm trying to put this diplomatically. I do know how to calculate pressures in a hydrostatic system, and I've even read the Canon patent on the subject. I gave you a physical model, which admittedly is a little simplified by putting the sponge away from the walls, in order to avoid having to explain the concepts of hydrostatic potential and capillary potential. EDIT: It's even simpler than that. Let's just say that if there is any leakage path through, under, or around the sponge, it will leak out if the hole is under the water line.
Now to answer Redbrickman's and your messages. Yes, it could leak out the bottom if there were a hole in the ink chamber, because you have up to 3 or 4 cm of head. But no, because the ink chamber is intact, even without the sponge it might not leak from the exit port, because you have only a few millimeters of head. Remember that you have to overcome the capillary action of the filter (and as you have drawn it, the sponge). So no, I don't think your diagram is correct. We can't be sure without knowing the capillary properties of the filter (and the sponge would certainly prevent the leak).
The vacuum in the ink chamber controls the level of ink in the sponge chamber, but it won't keep ink from coming out from a hole. The capillary action of the sponge and the filter is what does that--not the vacuum in the other chamber. To see this in action, poke a hole in a hummingbird feeder. Or just do a thought experiment. Put a sponge in there to stop it if you want.
Write what you want, but please, I don't want to discuss this any more. I've spent too much time on this.
