- Thread starter
- #11
soberprinter
- Jan 31, 2014
- Erie, PA USA
- Epson 2400, 1400, 3520, 410
The installing of wutenprint appears to be for use with GIMP only. It also makes some registry changes that corrupt the use of Gutenprint using the method I explained to install it. It appears the registry changes take precedent over the environment settings and cause the spooler to fail (ie blow up). These references to wutenprint in the registry will have to be removed by hand editing before Gutenprint (PhotoGP/ WinGP) will function properly. I'm not going to even begin to explain editing the registry here. If you installed Wutenprint, I'm sorry, you're on your own.
