- Thread starter
- #11
- Dec 27, 2014
- Location
- Germany
Yes, that's the game, no physical handling of the cartridge, I'm doing the simulated cartridge change cycle via the status monitor on the computer, only when a cartridge is reported empty/not recognized another button shows up in the status monitor - 'How to...' 'Wie Sie' .. (den Patronenwechsel starten) - (this 2nd part of the text not visible), you click several times onto the button - moving the carriage to the exchange position - that's the best position for refill, into the cartridge still seated - you continue to click onto the button in the status monitor - some steps take a few seconds , and the printer goes into the normal position with a cleaning cycle. If not - you click through that cycle a 2nd time, and it should work. With the next print command you will first get a screen telling you that you are not using original Epson cartridges which you have to confirm, and the printing starts. I never tried this via the ink button on the printer itself so far.I understand correct, you don't have to pull out and put back in the cart, just press the ink button again to continue?
Actually I didn't find that out accidentally , ARC chip cartrigdes for the R265 do the same, but not anymore on the R285, so since the R800 and R265 are about the same generation I was hoping for the same behaviour, and it got confirmed. The benefit is that the ink flow is not interrupted in any way by a refill, so I just can continue to print. And there is not need for a power off/on cycle to reset cartridges either. And even so, a power off/on cycle would be better for a reset since you wouldn't have to touch the cartridge either. This approach works and worked with various different types of ARC refill cartridges including those as part of a CISS so I just would assume the same for the R800 - just try it, nothing can go wrong. As you describe it - it's always a little bit of air getting into the pipe with every exchange cycle requiring a nozzle check and further cleaning . I have some other ink on order for more tests. Farbenwerk offers some 'Pigmera' ink for the R800 at this time as a HighGloss ink, but it's not a breakthrough ink yet.
