Epson Stylus CX3900 2024 Problem
Ranma2264
Print Lurker
Epson Stylus CX3900
Hi all,
I have the mentioned Epson in the title, I am facing issues that I never had before. The printer came back to me from a family member and I loved it ever since because of its capacity of having such an easy kit of rechargable ink cartdriges. When I refilled the ink everything went fine, including the cleaning nozzle. However when I tried to print all I get are horizontal lines from all the colors or either a mix of colors as well. I tried doing the power on self test, scanning a sheet of paper in color or grayscale, but no matter what I do the result is always the same, colored lines all over the paper and no sign of anything that looks like what I sent to the queue (attached image).
I also cleaned the heads manually with isopropyl alcohol and a cloth, to no avail. I do not know if it will be possible to reset the firmware on these kind of devices, or what approach should I take to fix the issue, the printer has sentimental value, so all in all I'd love to rescue it and restore it, any suggestion would be appreciatted. Thanks!
L805, WF2010, ET8550
Please post a nozzle test print to see which colors are possibly affected.
You may do a printhead flushing as shown in this video, and there are plenty more on YT
I'm not sure to understand what is epxected from a firmware reset ?
Do you have the chance to connect the printer to another computer and print there as well a test pattern, this should show directly if the computer or the printer is faulty
