tmierzwa
I purchased a CISS from a place in the UK. It performed flawlessly for over a year then started giving problems with the BLACK ink. Images were missing, images were blurry. After a lot of thinking, I had a bottle of ink that I used that must've been pigment based ink. Pigment based and dye based don't mix. What I ended up doing is completely emptied out and flushed the tank and silicone line. I then emptied the cartridge completely and flushed some water through it to clean out all the crap. I used a syringe with out the needle and forced water through the top opening of the cartridge. I did this several times over a cloth. Once all the liquid came out I kept on forcing air through it to get rid of everything. Ink the consistency of heavy oil came out in blobs. I left the cartridge out in contact with a damp cloth for two days. More stuff came out. When I got some ink I ordered, I filled the cartridge to prime it, then filled the tank with the same ink and force primed the ink line. I printed out a test page and had no problems. I printed out a 29 page document with no problems.
