Based on some bad personal experience, I'm getting the impression that within the last 4 or 5 years Canon has designed their print heads to last a relatively short time, after which that failure disables the entire machine. Did I just have bad luck, or are you guys getting limited usage out of your Canons now too?
I forget the model of the previous Canon I had, but it used cartridges identical to the CLI-8's, but without the chip. It printed well for years, and when that one died, it didn't owe me a thing. A little less than 4 years ago, I bought an MP610 all in one because that was one of the last models still in production that used the resettable CLI-8 cartridges, and the next generation of printers used cartridges that held less ink, IIRC. My BCI-8 cartridges had been refilled 8 times when I got the message along the lines of 'Print Head Not Recognized' or "Wrong Print Head', after which the machine wouldn't power up. No green light; nada.
I can find similar stories on the web on a variety of different models of Canon printers. Are those of you who are heavy printers seeing the same thing, or did I just have bad luck? I was considering a used ip4500 but I'm leery of getting something whose life expectancy is limited. I'm getting the impression that the Epsons may be replacing Canons as the printer of choice for longevity and refilling although they use more ink - apparently because of their cleaning cycle.
