The right pad is for the color ink. You can see the color on your photo. Your color purge subsystem is not working. Continue to flood the purge pads until Windex on the right pad is drained. You may need to leave Windex overnight to work on the clog. Some member had remove the pads to clean the pads and the pad holders with success. Clean the bottom of the pad holders. Make sure the Windex is drained away.esp said:Ok print head has been sitting 2 days and its dry now. I still haven't put it in the carriage yet.
I wasn't sure if I had to have the print head in to see if the purge system works. I decided to fill each pad with windex. I closed the top. Waited , opened it up and only one pad is empty. The one farthest to the right is still full. Now what?
Don't put the print head in your printer yet until you solve the purge system problem.
